Help with TP - LINK TL - WR2041N usage
snowfire
I recently brought a TP - LINK TL - WR2041N but no noe can explain how turbo mode works at all. also how do i change the firmware or find a manual for it? the tp link site gives me nothing.
Any help would be appreciated (:
I recently brought a TP - LINK TL - WR2041N ... also how do i change the firmware or find a manual for it? the tp link site gives me nothing. Any help would be appreciated (:
I can help direct you regarding the firmware.
Contact Uniterm Direct - JHB and ask to get through to Technical Support
http://www.dbg.co.za/contact_us.php?osCsid=1fkn23lgm6hof0rmukgi88sls6
Whoever helps you should be able to e-mail the latest TP-Link file/s.
Ask them about the manual at the same time .. and for that matter, about the Turbo Mode.
Hi There,
I O U +1 The support from Uniterm has been great in the past so go with them.
I had a quick look around and most of the references to it were in Mandarin and I am a bit too rusty to read it.
Regards
Tim
China, its cheaper than we get them here. I'm specifically trying to find a firmware that will update it to english...my chinese is rusty as hell. Thanks i did try using the site and then access download then it just gives me an error though :/
