dracolusus
- Jul 28, 2006
Hi guys,
I've got a problem and I need some help. I reloaded my PC with RAID, dual boot of XP 32 bit and Win 7 64 bit 7048 build. I have 2x250GB that I made into RAID 0 with 2 partitians (Shows as D: and F: ) and a spare 500GB for storage. (shows as C
. Loaded XP on the D partitian of the RAID and Win 7 on the F:
On XP the Array's partitian's and 500GB shows up fine, all good. But on Win 7 it only shows the Array and the 500GB doesn't show at all!!!
Any idea's what is can be? I have loaded all the SATA/mobo drivers etc...Should I reload and put Win 7 on the 500GB?
Anyone had this problem before? I've not used RAID in years and never used Vista (besides installing and uninstalling it a couple years ago when it caused nightmares for me)
