Help with WOTLK?
guest2013-1
guest
Hi, upgraded using the online system they provide but I don't want to download the 8gb client (not enough disk space anyway) how can I upgrade the client? I have v3.0.3 already?
It wont be 8gig to download then,about 1.2-2.4gigs.
Install from TLK cd or download that tlk update
The installer says I need 8gig diskspace. For the download...
Needing 8 gig for install or 8 gig for download are 2 different things,and you'll note the former rather than latter is true
Needing 8 gig for install or 8 gig for download are 2 different things,and you'll note the former rather tan latter is true
+1
It said i need 6gb to install, temp data afaik
Indeed. It basically backs up all the WoW mpq's and then patches them and moves them back to prevent corruption of the original files if something went wrong.
huh... okay, so I guess I'll delete my porn then
Just temporarily, can back it up on CD and put it back when your done ;)
After the game have been installed with the new updates it will actually take up less space than what it currently does. There is a lot of redundant stuff that they have removed or streamlined.
