Which ROM exactly did you install and what hapens if you poke one of those buttons? I've used the Mi Flash tool a few times in the past couple of months with no problems.Hi. I picked up a cheap Redmi K20 Pro but it had a custom rom I did not like. I used the Mi Flash tool to install a stock rom and after booting up it shows this screen. What is this and any suggestions on how to fix it?
I installed a Chinese ROM a few weeks ago (there wasno Global out at that point) but it had Engish subtext and immediately allowed me to switch language to English, so it was no problemI think it was a Chinese Rom. Thanks I actually just did the same thing with Google Translate.
I did not relock the bootloader, but the TWRP recovery is gone.Would OP be able to load a custom ROM in this case (unless he selected to relock the bootloader when flashing back to MIUI.......)?
Maybe try the MIUI Indian ROM, I suppose you need to re-enable ADB before being able to flash another recovery?I did not relock the bootloader, but the TWRP recovery is gone.
You can reflash TWRP recovery with adb while the phone is in fastboot mode, usually in recovery it will allow you to mount the storage and you can copy your new custom ROM over.
Unfortunately, this is the only way to use the phone if it has been Mi Account Locked
