Help
Alansnyders
Hey,
I am new to HA.
I currently have a few sonoff zigbee contact sensors , and motion sensors, Phillips hue hub and bulbs, SmartThings and a few yeelights.
1. Should I still attempt to flash the sonoff devices since I connected them to SmartThings hub, does this mean they are local?
2. Is there a way to use the SmartThings hub as a zigbee gateway for HA instead of getting a separate zigbee usb stick for HA?
3.if I have to get a usb zigbee stick for home assistant, should i bypass the Phillips hue hub and connect all the Phillips globe directly to home assistance to increase the zigbee mesh network?
Thank you
Maybe wait till Monday and then give your post a bump :)
Sometimes it's quiet in here over weekends.
