Help
marine1
A black hole in the universe - JHB
Hi guys, I just smashed my Sigma lens, the 170-500.
Any idea where I can take it to get it fixed?
The housing is cracked.
I also need to get my internal mirror cleaned - Sony Alpha A700, where in JHB can I take it?
AFAIK Tudor Photographic in Cape town handles all sigma repairs in SA.
ahhh man sorry to here - never get a good feeling hearing that.
Tip to everyone: Put a UV filter on all your lenses, it might just save you one day.
A filter probably wouldnt have prevented a cracked housing.
Sorry - but I'm anti UV filters in general.
haha alot of people are. Tell me why please.
They can help hey, seen a lot of cracked UV filters which have saved people thousands of rands. so i have always used them.
In my experience they lead to flaring.
Unless you're using a wide angle lens, which have those shallow lens hoods, a lens hood should prevent anything - short of a spike :) - from even getting near the glass.
Introducing any glass or even some empty space (macro tubes) is going to affect light that travels through it. Your thousands of rand lens has superior glass and adding a UV filter would degrade quality so why spend that much on the lens?
I don't have an opinion either way. I personally use the PRO Kenko UV filters on my lenses. You will definitely see a degradation if you use cheap filters.
