Harmonic
If you had 250k to play with and had the below constraints, what would you buy?
Constraints
Constraints
- Budget 250k
- Max instantaneous load, 7kW
- Average usage per day, 10kWh with 70% of this used during daylight hours
- No grid backup
- Resiliant in the case of a panel, battery or inverter failing
- The system has gas geysers, water heating doesn't need to be considered
- Pumping water is not required
- A suitable generator has already been acquired, but design wise, more minimal generator usage is desired
