Wonder if anyone can help me shed some light on this.
Background: I've got a client that, AT RANDOM TIMES, use up to 1gb internet per day. Have installed Netlimiter on PC's, removed PC's from network, changed router passwords, changed ISP passwords + DSL secure, disabled wireless on their NetGear DG834GUK, etc etc. Some days it's fine (100-150mb), other days not (500-1500 mb).
This weekend I logged into their PrePaid WebAfrica account, and saw they used 500mb on Saturday. They don't work on Saturdays, and only the Server is on. What is strange though, is that it's EXACTLY 250mb received, 250mb sent (ie, equal upload and download).
This morning I got a brainwave and checked the Firewall rules on the Netgear itself. It was set to allow ALL incoming traffic and direct it to the server. Removed that, and also copied the LOG. [EDIT: I see now it was sent to the Server's secondary Network card - but I changed the infrastructure around so that it's only on 1 Network card now, so that forward should have done nothing then. Ignore]
* Note that I removed the client's last two IP digits.
Question: Does any of that in the log look suspicious? I use LogMeIn to connect to their server - so that might explain some of the entries in the log? [EDIT: I cleared the log, and logged in via Logmein - nothing was logged - so assume it's not LogMeIn?
Is it possible that someone / something used their router as a relay of some sorts? And what does all these entries in the log mean? Can I check where these come from, and what the ports are used for?
Tx.
Sun, 2002-09-08 12:02:46 - PAP authentication success
Sun, 2002-09-08 12:02:56 - Send out NTP request to time-g.netgear.com
Mon, 2009-11-02 06:23:54 - Receive NTP Reply from time-g.netgear.com
Mon, 2009-11-02 06:25:02 - TCP Packet - Source:190.42.42.1,2666 Destination:41.243.xx.xx,23 - [Any(ALL) rule match]
Mon, 2009-11-02 06:25:03 - <DDNS>Update OK: good
Mon, 2009-11-02 06:25:49 - TCP Packet - Source:83.4.43.244,3949 Destination:41.243.xx.xx,23 - [Any(ALL) rule match]
Mon, 2009-11-02 06:26:44 - TCP Packet - Source:41.242.145.109,13601 Destination:41.243.xx.xx,135 - [Any(ALL) rule match]
Mon, 2009-11-02 06:20:57 - Router start up
Mon, 2009-11-02 06:42:11 - ICMP Packet - Source:41.185.86.62 Destination:41.243.xx.xx - [Any(ALL) rule match]
Mon, 2009-11-02 06:42:27 - TCP Packet - Source:41.185.86.62,2487 Destination:41.243.xx.xx,8080 - [Any(ALL) rule match]
Mon, 2009-11-02 06:42:28 - ICMP Packet - Source:41.185.86.62 Destination:41.243.xx.xx - [Any(ALL) rule match]
Mon, 2009-11-02 06:47:45 - ICMP Packet - Source:41.243.38.212 Destination:41.243.xx.xx - [Any(ALL) rule match]
Mon, 2009-11-02 06:48:32 - ICMP Packet - Source:193.86.3.39 Destination:41.243.xx.xx - [Any(ALL) rule match]
Mon, 2009-11-02 06:48:44 - ICMP Packet - Source:41.243.38.212 Destination:41.243.xx.xx - [Any(ALL) rule match]
Mon, 2009-11-02 06:53:33 - TCP Packet - Source:41.243.58.206,1302 Destination:41.243.xx.xx,445 - [Any(ALL) rule match]
Mon, 2009-11-02 06:53:33 - TCP Packet - Source:41.243.58.206,1303 Destination:41.243.xx.xx,445 - [Any(ALL) rule match]
Mon, 2009-11-02 06:59:16 - TCP Packet - Source:41.243.227.48,31448 Destination:41.243.xx.xx,445 - [Any(ALL) rule match]
Mon, 2009-11-02 07:04:57 - TCP Packet - Source:208.126.55.93,12006 Destination:41.243.xx.xx,445 - [Any(ALL) rule match]
Mon, 2009-11-02 07:12:32 - TCP Packet - Source:75.175.126.51,2668 Destination:41.243.xx.xx,23 - [Any(ALL) rule match]
Mon, 2009-11-02 07:13:34 - TCP Packet - Source:151.32.37.226,4831 Destination:41.243.xx.xx,23 - [Any(ALL) rule match]
Mon, 2009-11-02 07:13:46 - TCP Packet - Source:59.93.241.231,2276 Destination:41.243.xx.xx,23 - [Any(ALL) rule match]
Mon, 2009-11-02 07:41:41 - TCP Packet - Source:41.243.159.30,3287 Destination:41.243.xx.xx,445 - [Any(ALL) rule match]
Mon, 2009-11-02 07:47:47 - TCP Packet - Source:41.243.159.30,3533 Destination:41.243.xx.xx,2967 - [Any(ALL) rule match]
Mon, 2009-11-02 07:53:16 - ICMP Packet - Source:41.243.30.179 Destination:41.243.xx.xx - [Any(ALL) rule match]
Mon, 2009-11-02 07:57:07 - TCP Packet - Source:41.243.159.30,3710 Destination:41.243.xx.xx,445 - [Any(ALL) rule match]
Mon, 2009-11-02 07:57:10 - TCP Packet - Source:41.243.159.30,3172 Destination:41.243.xx.xx,139 - [Any(ALL) rule match]
Mon, 2009-11-02 07:59:27 - TCP Packet - Source:41.243.159.30,3090 Destination:41.243.xx.xx,2967 - [Any(ALL) rule match]
Mon, 2009-11-02 08:17:43 - TCP Packet - Source:85.20.132.189,4944 Destination:41.243.xx.xx,23 - [Any(ALL) rule match]
Mon, 2009-11-02 08:21:05 - TCP Packet - Source:201.230.50.193,3197 Destination:41.243.xx.xx,23 - [Any(ALL) rule match]
Mon, 2009-11-02 08:23:18 - TCP Packet - Source:196.20.164.180,4027 Destination:41.243.xx.xx,23 - [Any(ALL) rule match]
Mon, 2009-11-02 08:29:35 - TCP Packet - Source:41.243.142.206,4629 Destination:41.243.xx.xx,445 - [Any(ALL) rule match]
Mon, 2009-11-02 08:29:38 - TCP Packet - Source:41.243.142.206,3113 Destination:41.243.xx.xx,139 - [Any(ALL) rule match]
Mon, 2009-11-02 08:29:42 - TCP Packet - Source:41.243.234.71,28343 Destination:41.243.xx.xx,445 - [Any(ALL) rule match]
Mon, 2009-11-02 08:29:42 - TCP Packet - Source:41.243.234.71,28344 Destination:41.243.xx.xx,445 - [Any(ALL) rule match]
Mon, 2009-11-02 08:32:25 - TCP Packet - Source:196.205.169.242,2620 Destination:41.243.xx.xx,23 - [Any(ALL) rule match]
Mon, 2009-11-02 08:33:15 - TCP Packet - Source:66.222.115.227,2970 Destination:41.243.xx.xx,23 - [Any(ALL) rule match]
Mon, 2009-11-02 08:58:40 - TCP Packet - Source:41.243.234.71,23500 Destination:41.243.xx.xx,445 - [Any(ALL) rule match]
Mon, 2009-11-02 09:02:27 - TCP Packet - Source:41.243.220.252,4290 Destination:41.243.xx.xx,23 - [Any(ALL) rule match]
Mon, 2009-11-02 09:03:04 - TCP Packet - Source:190.40.120.204,3357 Destination:41.243.xx.xx,23 - [Any(ALL) rule match]
Mon, 2009-11-02 09:07:45 - TCP Packet - Source:41.243.142.206,3344 Destination:41.243.xx.xx,2967 - [Any(ALL) rule match]
Mon, 2009-11-02 09:08:37 - TCP Packet - Source:201.230.82.154,3506 Destination:41.243.xx.xx,23 - [Any(ALL) rule match]
Mon, 2009-11-02 09:11:54 - TCP Packet - Source:41.243.90.57,1919 Destination:41.243.xx.xx,135 - [Any(ALL) rule match]
Mon, 2009-11-02 09:14:49 - TCP Packet - Source:41.243.142.206,3902 Destination:41.243.xx.xx,445 - [Any(ALL) rule match]
Mon, 2009-11-02 09:20:17 - TCP Packet - Source:41.196.92.230,4636 Destination:41.243.xx.xx,23 - [Any(ALL) rule match]
Mon, 2009-11-02 09:20:22 - Administrator login successful - IP:192.168.0.1
Mon, 2009-11-02 13:33:57 - Administrator login successful - IP:192.168.0.1
Mon, 2009-11-02 13:44:12 - Administrator login successful - IP:165.145.xxx.xxx(ME)
Tx.
