WickedWeasel
Him I am almost next door the Bryanstone Water Tower however, I cannot get higher than 200k download.
Any Ideas ?
Any Ideas ?
WW, just wondering if you are still getting this problem, and more important to me personally - which side of Bryanston-bs are you on (North South East West)?WickedWeasel said:Him I am almost next door the Bryanstone Water Tower however, I cannot get higher than 200k download.
Any Ideas ?
[thread=16486]Try finding it under TCPIP/Parameters in the registry as per following thread.[/thread]noone said:MTU Path whatchamacallit?
[post=154713]How2-Set-iBurst-MTU-4-Windows2000Professional[/post], should be fairly similar to XPP.noone said:parameters?
/me moer ic
wtf?
An MTU > 1392 will definitely give you problems where packets are being fragmented, which will result in a major slowdown, best to stick with MTU == 1392. I am going to update the other MTU & RWIN thread I started a while back.noone said:Mine was set to 1400![]()
