Hisense A85G OLED - 120hz?
ClarityJuice
Hi all,
Curious as to why the box on this tv says 120hz "Native". Can only choose 120hz if I use 1080p.
Is this some marketing jargon? Thanks
Probably only HDMI 2.0 ports, there isn't enough bandwidth there for anything higher than 1080@120Hz.
This is what I was thinking, why though, does the box say "native 120hz". Fairly false?
The panel itself supports it, but yep it is misleading to most consumers.
I wouldn't touch HiSense in SA as we get cut down cheaper versions that have the same main model numbers as the international variants.
