HOME AUDIO RECOMMENDATIONS
REDI
Advice needed on a receiver, speakers (preferably wireless) for a standard sized lounge. I've seen package deals and am wondering how good these are.
Should i go stock standard home theatre setup or receiver,plus blu ray+ 3D sound. I am a novice so any good suggestions would be welcome.
Many SA living rooms have poor acoustics. Perhaps give a quick run down of what you use the sound system for and if movies what kind of movies.
If you're considering a Sony Mgongo or HT in a box rather look at going stereo with good used floor standers or similar. You won't look back once you've set them up correctly.
