Will be moving into a new house and I'm hoping to lay down a solid WiFi network in the new place. (After having to reset my current router multiple times a week). It is a 350m2 double story with the Fibre connection point approximately in the middle on the ground floor. There is a LAN cable running up to the 1st floor.
The idea is to be able to get at least the full line speed at any point in the house, but hopefully a bit more for future proofing.
Currently I'm deciding between the Ubiquiti UniFi Dual Band AC Lite AP (either in-wall or ceiling mount) and MikroTik cAP AC AP. However, I have the following questions that I'm hoping to get some assistance with:
- If I go with the UniFi APs, is it recommended to get a UniFi router, switch and controller as well? For example, will the APs still function optimally without the controller software? How much features would I sacrifice by going with a non-UniFi router? Going all-in with UniFi devices will increase the cost substantially.
- Is either solution significantly better at roaming? I'm not necessarily looking for completely seamless, zero-handover roaming, but devices should at least move over to the best AP eventually.
- How many APs would you recommend based on a 350m2 double story property?
- Would a Mesh network work better? (keeping in mind that I'm happy to run cabling for wired APs instead)
- Also happy for suggestions other than Ubiquiti and MikroTik as well.
