Anyone managed to install or configure a Sonnoff product to control (up and down) roller blinds?
Or a similar product compatible with Homebridge?
Have you used the Aqaras before? I've been looking at them for a number of use cases (roller blinds, motion sensors, door contact sensors)Skip Homebridge.
Go Aqara and put it straight onto HomeKit.
Yeah have the items in my takealot cart, will start with a hub, contact sensor and blind controller... I won't have them going into home kit though, straight into HomeAssistantOnly the cameras so far.
It’s on my upgrade path when I replace my blinds.
Probably the ones that pull the drawstring for you as they are much cheaper.
Their hub let’s you pull non-HomeKit stuff into HomeKit too.
