Honest solar payback calculator
TheOracle
The whole point of this tool is to get a honest payback calculation. Most solar calculators assume you use every single kilowatt your panels make, that electricity never gets more expensive, and that your battery lasts forever. None of that holds in real life. So this tool gives you two payback figures side by side, the optimistic one a salesman tends to quote, and the realistic one you are actually likely to get, then it lists exactly what eats the gap between them.
Anyone interested can have a look here:
In line with my own calculations. In the middle of next year, I will pay it all back.
The calculator assumes you pay cash for your installation but that is usually not the case. I will see if I can add a proper finance mode, a box for the amount financed, the rate and the term, so the chart can show the repayment line against the saving line and give you the real break even rather than the cash one.
And the fixed charges are not mentioned. It looks like it assumed prepaid but not postpaid. Or if One has no fixed charges.
Your normal monthly fixed charge isn't included on purpose, because it stays the same whether you have solar or not, so it cancels out and doesn't change the payback. Solar only saves you the units you stop buying.
The one thing to watch on a postpaid account is the rate you type in. Use your energy charge per kWh off the bill, not your total bill divided by units, otherwise the savings come out too high.
But I am off-grid. So it changes the calculation as I don't pay the fixed charges. I had to factor it into the calculator by including the monthly fixed charges in the per kWh cost for CitiPower postpaid.
So there must be an option to enter what the fixed charges were for those that are not grid-tied anymore.
Fair point, I will have to provide for off grid. On my to-do list.
Not sure I trust it. My system cost me R145K about 4 years ago. Average year my system generates and saves me around 2-3MWh each year. At my cost of electricity this last year saved me around R7300. Not sure I will ever break even, buy happy to have paid for the system as its a lifesaver during load shedding and power outages which are getting more and more frequent in our area. My power has been off since Saturday right as the kids start exams. High plus that we can carry on to a degree and still cook, use lights and tech, etc. The calculator said payback was 7.9 years for me but I honestly think realistically its probably more like 15 years with how little I earn from the system vs its cost. Factor in the interest I could have earned on that same money and it gets worse.
Yes, it is missing the interest inpact. I will let you know once it is added, then we can see what impact it makes.
Do you just use that little power
Or all load not on inverter especially heavy hitters stove/geyser or battery limited
Generates 3000kWh a year? Tell me about it. That is 250kWh per month. R150k is stupid money to spend on such low consumption. A R20k trolley would have done the job. You will never pay it back if you never use it.
Just put in a new system a few months back
R240k , expected to save 15 to 20 MWh per year.
Usage is tracking expectations. Expected payback is 3.5 years. After some changes we use 60% batteries at night.
Family of 5
Did some changes with a gas geyser on the one. Geyserwise with tuya with 2kw ptc elements on all 3. Gas stove which is a no brainier. Geysers are the killer. The one with gas geyser has it configured as backup. When water temp is low diverted via gas geyser. If I have spare solar use it to heat that geyser. Saves some gas
Never been a fan of scheduling baths/showers because of small geysers
Saving on elec bill is r7k to 8k pm. Geyser and stove changes saved another r4k plus minus on top less 1 gas refil every 1.5 months at about 1.5k ish
House came with a 3phase 10kw diesel generator which I incorporated into the build. If needed I can run for 3 to 4 hours, fully recharge batteries which can then last 2 to 3 days if we turn off some non essentials
Busy working on sorting out the borehole filtering to go off grid.
Been working on getting a lot of the house on home assistant
Have a spare 5kw battery trolley that will be sold. Was from prev house
Not sure where you get the battery prices but 4 x 5kwh batteries are not going to cost R30000 in 8-10years.
Family of 5
How much do you spend on gas per year?
Sorted. There is an off grid toggle now. Tick it and you can enter the monthly fixed charge you stopped paying, and that gets counted as a saving. Export and the extra solar fixed charge drop away since they do not apply once you are off grid.
Added the bit you were missing. There is now a box for what the money could have earned elsewhere, and it gives you a second payback once that is counted. Plugged your rough numbers in and it lands around 15 to 17 years, pretty much where your gut put it.
I have also added a finance mode. You pick cash or financed, drop in the deposit, rate and term, and the chart break even now reflects the repayments instead of pretending you paid cash.
Winter. 1 48kg every 1.5 months. Summer I am expecting a bottle to last 2 or 3 minths
Atm after all the price increases I pay about 1500 for a 48 refill
Seeing you use 5 bottles a year @ R1500 per bottle = R7500, that is money that could be going towards batteries instead by using induction stove and heating water during the day when the sun is shining.
