How can I get 2 numbers going to 1 device?
dudleygb
CT: the best place in SA
Hi, I have 1 prepaid MTN no I've had for zonks and a new MTN no. Is there anyway to achieve the result, where, when somone calls either number it comes to the same handset?
Divert calls from the one to the other.
Other than that... I dunno.
Ask your network to enable fax and data on your line. When fax is loaded they will give you a second number.
Now you have 2 numbers on 1 SIM and although you are meant to receive faxes on the second number, it works just as well for voice calls.
Diverting costs money. Get a dual sim mobile, I know that basically all the Chinese phones have dual sim capabilities. I used dual sim with the phone in my sig and it's pretty decent.
