sybertiger
how can i use adsl2+ and not adsl 1?
i set it in my router but it wont connect any help?
i upgraded to 10mbps but i sync on 6mbps
Downstream Upstream
Current Rate(Kbps) 6144 640
Max Rate(Kbps) 9620 1000
Noise Margin(dB) 12.8 12
Attenuation(dB) 39.5 22.5
Output Power(dBm) 12.5 10.5
u think 8mbps may be possable if i phone telkom and ask to bump me up ?
are there a way to boost my SNR?
just a quick question,if my exchange can support adsl2 will it connect on it,or do i have to ask telkom to put me on adsl2?
anywas i will phone them tommorrow and ask for 8mbps maby i am luckey and it all runs good if not it really sucks...
and one more thing, will my sync automatically go higher if it can,or do i have to ask telkom to do it?
on the adsl checker it said max in my aria 4mbps
till last month
i saw it said max 10mbps i was like YAY!!!!!!!!!!!!!!!!!!!
then i phoned them and ask to bump me to 10mbps
but like u say 6mbps is the most stable i can get
so they put me on it.ur still on the 4/10mbps one?
if so downgrade to the normal 4mbps one for 299pm
just ask for a bumpthats all i did
well u think its worth calling telkom to test out 8mbps?
maby it wont be bad
was so happy to see i can support 10mbps,but nope (cry)
same good lucK! hope u get 10mbps
i want 8mbps but it may be unstable and wiht my trendnet router ists allready a pain in the ass
so unstable line+ trendet + telkom = pure hell
