How do I find my Tower Location?
MrJones
JHB
Ok well the question is this, We all know that using a cantenna dramatically improves your signal strength. But how do I find out the geographical location of my tower, so that I can point the cantenna in that specific direction. I know we can find the GPS co-ordinates, but how do I convert that to street address or jjust general direction?
Quarter Pounder with Cheese Please
If you know your location's GPS coords, and the Tower's GPS coords, you can use simple Geometry to find the direction to the tower from your place. Or just go to braby's maps (I think it's www.brabys.com or something like that) and enter the GPS coords of the Tower. I'll center on the tower. Then find your place relative to the tower and you got a general direction.
Go get ProAsm's MySignal, Its a live signal monitoring tool. So you can monitor your signal while messing around with the cantenna, and find the ideal spot.
________________________________________________________________________________________
Durban Mal Park(36) 36% SNL-12 128k | D-Link Tri-Mode Dual Band Wireless router | 802.11G PCI card |irc.shadowfire.org #mywireless
I'm sure if you mention which tower you're connecting to, as in i.e. 36 Menlopark or 60 Bedfordview, someone might be able to tell you quickly where that tower is
128K|20%|12SNL|36 Menlopark 2530
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Rhino</i>
<br />Go get ProAsm's MySignal, Its a live signal monitoring tool. So you can monitor your signal while messing around with the cantenna, and find the ideal spot.
<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
That's not necesarily the direction of the antenna though. You might get a stronger signal by pointing slightly to the right or left of a tower.
And by doing that you might have a weaker send signal, which you can't measure with the ipwireless driver...
So who knows where the Tower in Bedfordview is? Tower 60 I think....
Hmm - dunno - I know that 66 is possibly the Brixton tower - when I was out with my laptop some time back, I got 60 at cresta.
4 days to go ... gloats ... [:D]
Vat hom Fluffy!
Forgot to say, MrJones, the Cantenna does nothing unless you are experiencing signal loss.
If you are and the cantenna fixes that signal loss, you are still connected to a service that has been - hmm, how can I put it ? - castrated ! - yeah, that works.
I'm loving surfing with Sentech round-a-bout now (on my last 4 days - gloat) - but too little too late and too much bandwidth management.
Sentech is now for the mweb crowd - email and solitaire ...
Vat hom Fluffy!
Go here MyWireless Tower Distance Calculator:
http://www.rational.co.za/Mywireless/calculate.html
BTW Anyone hear the iburst ad on 5fm?
custenna, variable 2 - 13 signal, ber 28% - 42%.<i> "I am the only one with this problem." </i>
To condense the above into what you're trying to achieve:
1. use the sentech zonelocator, at http://66.18.65.122/zonelocator/welcome.htm to find your site/address
2. once you've got the location, open the abovementioned rational distance calculator in a separate browser- he DOES have accurate tower data
3. get the 2nd browser ready to take input (in whatever city you happen to be)
4. use ALT-TAB (presuming Windows usage here..) to flip back to your zonelocator page and hover the mouse on The Spot(tm), ie your site
5. look in the bottom LHS of the zonelocator and it'll show you the GPS data for your site
6. without moving the mouse, flip back and forth between the zoneloc page and the rational page and input the numbers
7. get the rational site to give you its numbers- which'll be distance (mildly interesting to you at this stage) and bearing
8a. know how to convert that bearing number into something useful outside/away from the browser- knowing north helps here
8b ..cheat by using a GPS- 's what I do *G*
On a separate note, I wouldn't count TOO much on a cantenna "dramatically" improving your signal- but it's certainly worth a try! But you should be able to get the thing aimed in the right direction. Also, as mentioned above, the ProAsm dialer is a GREAT tool to fine tune your signal, the method here is to go to the [MySignal] tab and click on the (yellow) phone icon- this'll switch on its live monitoring mode which'll enable you to do the search thing. You'll know you have it in monitoring mode by the icon going red and getting a fluctuating (level) yellow bar up the middle, and numbers jumping up and down as you hunt around for the best position. Tip- do BOTH axes- I'd recommend doing the horizontal plane (technically known as azimuth) until you get max numbers FIRST, THEN check out the vertical (elevation) plane to get the sweet spot. Then make DAMN sure you lock that position down in some way ..duct tape may help at this point! *efg*
And if the cantenna gives you the improvement you're looking for, you CAN relax once your signal goes over 21%- I find that's usually the point that the BER number hits 71%- the highest it ever seems to go. If it doesn't do like you're hoping- well, sometimes you luck out and find someone in this bunch of semi-literate malcontents that actually posts something helpful!
Thanks for the excellent response bdt, checking now.
"...semi-literate malcontents.."
I take &lt;*edit*&gt;<s>offense with</s> resent that. I consider myself a very literate malcontent. [;)]
*Edit* <i>...mumble...picky @nal b*stards....</i>[:I]
The evidence belies the fact - it's 'offence <i>at</i> that', not '<i>with</i>' - sorry, just my anal response to a cr@ppy Monday... [;)]
