If anybody can shed a bit of light on this... this is just what I THINK happens, and if you know better please help out.
So what I have been able to piece together is that I get my access from telkom, which is a copper wire between my modem and the closest exchange... which has equipment called MSAS, SSEXY, LMAO, WHATEVER and etc.
At the exchange, the device I'm physically connected to, acts like a bandpass filter for every other user also connected to it and on the other side it combines everybody onto a (hopefully) larger connection that connect to... what?... (getting a bit fuzzy) a bigger exchange I suppose?
That exchange is then again connected up/down the line to my ISP (which I connect to using some kind of rudimentary DNS server and router) which is the gateway to their internet... pipe?
I'm sure this works on a lower level than IP4/IP6 because my first tracert hop is already at the ISP.
From my side it's called a DSL line, on the ISP side it's called IPC.
Now let say the ISP buy a 1mbit IPC, how do they then regulate the 20 users who are all also connected via a 1mbit connection? or do I have the cat by it's tail?
Thanks!
Thanks!
