How does Telkom LTE/LTE-A bundles work?
RetroK
Hey....is there anyone who is possibly using the prepaid LTE/LTE-A bundles (that are in the *180# menu) and not on contract?
I've been thinking about buying the LTE 10GB anytime data +10GB night data bundle, but am clueless about it. Can I just buy them like other data bundles? Or do I have to get my sim card registered or something? Please help..
krieg
I've been thinking about buying the LTE 10GB anytime data +10GB night data bundle, but am clueless about it. Can I just buy them like other data bundles? Or do I have to get my sim cars registered or something? Please help..
You need to change your package to Smartbroadband or something, once done the LTE bundles are available under the USSD menu. I think to change package is also under the USSD menu but not sure.
RetroK
Hi, I've already changed it to Smartbroadband Wireless Prepaid, and am also seeing the bundles in the *180# menu. But am still unsure if I can just purchase them, or if I need to do something else first to be able to use them.
krieg
You will need airtime and a LTE device and be in a LTE area that's it.
RetroK
Okay thank you. So the lte device, is it like a router? Or is it just a smartphone that supports 4G/LTE? Also I've checked the coverage map, and I am in an LTE area.
krieg
You can use a router or a phone with LTE yes. Under balances it shows the LTE data separately so you check if it goes off correctly.
BayCityRoller
To purchase data bundles from airtime on Telkom, the SIM card doesn't even need to be put into a 4G / LTE phone. I've been through this process plenty of times using an old Nokia 2310, and as recently as about a month ago.
You can also check data balances on that phone (or similar, old 2G phones) using USSD code *188#.
Just mentioning this in case anyone wants or needs to use an old phone for this on Telkom.
The same doesn't apply on Cell C - ie. last I tested, you couldn't even get a signal on that old Nokia 2G phone, but had to use a 4G smartphone.
Jake45
Some of the Telkom bundles have 61 day expiry dates so you could save money by buying a larger 20+20GB bundle and splitting it over two months if that is worthwhile. The night data portion would only be available for 31 days though but you could save around R24-50pm if you are mainly using the anytime data.
I think that you can also transfer data from those packages to different SIM cards which might also be useful.
If you load the airtime onto a different SIM card on the new Thola More Plan you should be able to score an additional 400~500MB of data (7 day expiry) as well as 100~200 Telkom to Telkom minutes and 100~200SMSs. After receiving your freebies you should be able to transfer the airtime onto your SmartBroadband plan SIM and then purchase the bundle of your choice on that SIM card.
Jake45
@BayCityRoller: Your previous message seems to have disappeared.
One other thing that you can do using the Thola More plan is to make small airtime recharges every week to make use of the freebies and only purchase the bundles every second month etc. You should be able to just leave the unused airtime in your account. None of the unused airtime that I have left on my Telkom SIM cards has gone missing so far but I don't generally leave large amounts on my SIM cards. If you recharge with R50 every week you get 200MB and 50 free Telkom to Telkom minutes. In the past I have used the free minutes to make long calls to Telkom numbers which might be costly. I generally use the TymeBank website to transfer airtime to my SIM cards which is a lot simpler than using prepaid airtime PINs from printouts etc.
If you check your Mo'Nice offers regularly you may find something worthwhile. They did have a 50GB 7 day Nightsurfer package for R49 a few weeks ago but I'm not sure whether this is still available. The Mo'Nice voice bundles for Telkom numbers are usually quite cheap and useful.
BayCityRoller
Hi again @Jake45 - yes, I took my last reply out as it referenced Axxess too much (ie. off topic), and negatively (which wasn't applicable here).
If you recharge with R50 every week you get 200MB and 50 free Telkom to Telkom minutes. In the past I have used the free minutes to make long calls to Telkom numbers ...
I'd probably have to have a 2nd smartphone to do this (re the data part) because my main SIM (on Vodacom) is too entrenched already in what I do - unless I ported that main no. .... but somewhat concerned it wouldn't work out the way I wanted.
I've kept with Vodacom all this time as recharges need to be as infrequent as once every 9 months (from info. I picked up years ago), and I hardly make any calls / use any SMSs, so Telkom's freebies aren't that appealing to me.
Also, these days, so many numbers are not on Telkom's network, but on independent VOIP systems.
That's probably why Telkom are so willing to give away free minutes on ONLY their network ?
You may have nos. of people / companies you already know are with Telkom, so that works out well for you, but short of trying a no. each time and either getting through on this Telkom-to-Telkom free minutes story, or not, I don't know how to find out beforehand these days, whether a number is with Telkom beforehand (especially those pre-fixed with city codes - eg. 011, 012, 021, 031 etc., many of which are now on VOIP).
But for free data, it might be worth trying to run a 2nd SIM in my case.
Budza
If using Telkom only data, disable data roaming so you stay on Telkom even if signal isn't great (better than hopping to VC where your data doesn't work anyway)
*180#13 -:> block Telkom-R
BayCityRoller
I think their Smartbroadband Wireless packages only run on the Telkom network, and when I did a dummy run to purchase for eg. a 5GB + 5GB package on a SIM that wasn't converted to Smartbroadband Wireless, if I remember correctly it also popped-up with the warning that you must ensure you have Telkom coverage as there's no roaming (but I may be wrong about this ?).
The_Ogre
"Refreshing SIM Data".
Be prepared to see that a lot with the LTE bundles when you are out of LTE coverage.
What I do is buy the LTE bundle and then a 1GB All Network bundle for those times that I don't have Telkom LTE coverage. Works well.
Budza
Per my response above, I prefer to block roaming altogether. That way I know what I'm paying for the data used (I have a dual SIM phone, so if there's no Telkmo LTE I can switch to my FNB Connect SIM).
