Thanks guys.
I am using the remote Blaster now and it works well but as soon as the unit loses alignment (I have kids) , changing channels is a mare. Will try out this TV Link.
Attached MC manual, I prefer to split the heart-beat cable with a T-piece. Connect the heart-beat RF OUT on both decoders, change your communication port in the menu (Xtraview setup) to RF out on both. Relay remote command should be off, accept remote command should be on. Change remote mode to TV2 on one of the dec. Under TV setup, TV Link must be enabled. If you want to feed more than 1x TV on RF use a SLX splitter down the line to split. Also under TV setup check that the UHF frequency’s (ch) are different to avoid interference.
