How Ford tests its locally-built engines
My 5 year ownership with a FORD the engine was pretty reliable ( had the injectors changed under warranty when I kept getting a check engine light), but that Powershift Gearbox is what is a major let down they should test that more and fix that.
I actually thought that they would use the 3.0TDi from VW seeing that they are going to build the new Amarok
I assume they stress test them under conditions accurately simulating those that would be encountered in everyday South Africa... drive them over a strategically placed rock on the freeway and then set them on fire?
