How Namibia turns sewage into drinking water
Flojo
http://theweek.com/articles/668750/how-namibia-turns-sewage-into-drinking-water
Snippet (best click the above link):
On the outskirts of Windhoek, the capital of Namibia, there's a huge, churning vat of nasty brown liquid. It's so stinky that my guide, the man who runs Windhoek's water department, tells me I might want to stay in the car.
But this is what I came to see — raw sewage, on its way to being turned back into drinking water.
The Goreangab waste treatment plant is where most of the wastewater from Windhoek's 300,000 residents ends up. But it's not your run-of-the-mill sewage plant. It's the first stop in the city's pioneering water recycling system.
Cities around the world are wrestling with whether they should build facilities like this. But here, in the middle of a desert in a remote corner of southern Africa, they've been recycling wastewater for almost 50 years.
It's cutting-edge technology, but it's based on the humblest of creatures — bacteria.
"Everything is done biologically, by the organisms," explains Justina Haihambo, a process engineer at the plant. The bacteria help digest the human waste and pull it out of the water, essentially mimicking what happens in nature but a whole lot faster.
Speed was important when the plant was built back in the 1960s, and it's even more important today.
Wow Namibia, something we as South Africans could learn.
Namibian tap water doesn't have a good taste though.
Erm, it was built before 1990, when Namibia was adminstered by South Africa. The lessons have been forgotten post 1994...
+1 Before south africans built the first in the 60s, they never existed, south africa back then revolutionized water treatment the world over, all out of necessity for being water scarse, can't grow a country without water, so, they made a plan... every water scarce country in the world today now uses apartheids old water systems and management plans... just not south africa:D
Even if it doesn't taste good, I would argue that we could all get by drinking bottled water, and use 99% foul tap water for everything else.
Yes, taste is not the same as safety. Water can pass the most stringest chemical and microbial tests and be potable, but still not be palatable...
