MetalMilitia
- Aug 7, 2008
Hey Guys
After being fed up with Sentech's service and slow speeds i decided to go the ADSL route.....
Got my contract and free modem sorted within 3 days, i chose the self install option but im having some trouble.....
Can i connect the router to my pc without having to use the ethernet cable?
There is no option in the quick start wizard install for this, it demands ip settings from my local ethernet connection
Will i have to use the ethernet port on just one pc or can i do it all wireless??
The router is the 800VGT
Any help will be appreciated, need to get the ADSL up as soon as is possible
Thanks in advance
Thanks in advance
