InternetSwag
What is the best way in your opinion?
Use an OBD tracking device. It plugs into your vehicle diagnostic port and you can get etc codes , fuel, rpm, etc depending on the vehicle, device and software you are using
I have tested the Queclink GV500I’m assuming you have one… given your history and all.
Actually you can get it for your own personal vehicle as well, called SkyTrax/Track. Have it fitted and it shows you odometer reading, if the ignition is on or off, exact location. As well as a log of your speeds in various areas.Tracker has a system where you can track a vehicle live - you can see the speed, location etc.
Think it is only for Fleet options though.
