Hi Guys
Does anyone know how to program the DSTV A7 remote to use on an amplifier. I have programmed it for the TV but can't seem to find a step to setup with the amp. Thanks
Hi
Please explain the process I am missing from the steps below.
To set the tv the steps were the following.
1. Press and hold tv and ARC button for 3 secs. Then select brand via alphabet via the corresponding number on the keypad and hold till tv goes off. Then release button. Worked for the TV no issues.
Tried the exact same step but instead of TV button I used the AV button. That did not work.
Hi guys
How do I switch my tv on with the A7 model dstv remote. I managed to set the remote to turn the tv off but what buttons should I press to turn the tv on with the dstv remote.
