how to speed up mySQL import
Japster
Johannesburg
I'm having a 1.7GB mySQL data dump, and are busy importing it to a new database. The problem I'm having at the moment, is that this import has been running for 3 days non-stop. Is there anyway that a person can speed-up this import, as I really cannot sit till the end of next week and wait for this import.
i did set the ini file:
xampp/mysql/bin/my.ini
Set the following:
[mysqld]
max_allowed_packet = 512M
[mysqldump]
but this did not really help anything to improve the import speed.
Well I have been running it on an i5, with 8 gig RAM, but the import does not really use more RAM, I do not even use 3gig of RAM at the moment.
@Creeper, thanks for the article, will see if there is some improvements if I try some of the settings
There are just too many factors. How fast is your computer. Are you doing it over LAN. Are there indexes on the tables?
^^^ this, plus many others e.g. what software are you using for the ETL process, is transaction logging enabled, what does the schema look like, etc. ?
It may be a plan do go "old-fashioned" by exporting to CSV, then importing the CSV file.
I would not recommend the csv option. It gives hassles with datatypes and unicode. If what you have is a csv, then it is the only option, but a mysql dump is better where available.
I agree. That said, if the data is appropriate, it can be very fast.
Generally I prefer using an ETL tool.
I use the command line. I log into mySQL then switch to the database, and then use the source command. For example;
cd c:\xampp\mysql\bin
mysql -h localhost -u root -p
use databaseName
source dataFile.sql
Just have to say thanks guys, you helped a lot, database imported in roughly 15min where it took 3 days before and did not finish.
