So after a year, my 55W UV whole home filter system's ballast triggered a fault.
As I understand these light bulbs are only rated to last that long so I ordered a replacement bulb (+- R700
As soon as I turned it on the new bulb fused. Now Im not sure if its the ballast or the bulb that was at fault.
Is there a way to test these ballasts with a multimeter to check if they work? I saw online for a normal ballast you can do a resistance test, but when I do that at 2000k I get no reading.
Can I test its live output, I'm not sure if its AC or DC output (Chinese generic)
