How to use laptop's built-in 3G
ProfK
Randburg
I've just bought an Acer laptopn with built-in 3G, and I've bought an MTN SIM card. The laptop only has Vodaphone software pre-installed. How would I go about connecting to MTN 3G?
Try to download and run excellent MDMA for MS Vista, operator's independent, to replace your local dashboard.
Darius
It should have a dashboard loaded on it. The Huawei dash is called Mobile Partner. You can use any SIM with it.
he didn't name Huawei.
Some dashboard applications are build to communicate with computer facilities of a respective telecom operator, the same with firmware version.
Huawei advised me on one telecom operator provided with Huawei modems featuring USSD support for balance check.
Darius
