Hi
Thanks- I did have a look there- would prefer someone who actually knows what they doing to tackle.
@ aybbleek no graphics card yet.
If you're going to be using it as a HTPC you're going to need to get a low-profile graphics card with HDMI out for it for 2 reasons:
1) to actually render and display video content (especially HD)
2) for audio out over HDMI (there is no on board sound card in the HP MicroServer)
Then I would recommend increasing the RAM to at least 4GB, but if you're on a budget you can survive for now with the 2GB that is included.
Do you have an operating system that you would like for your base or would you just like to run XBMC as the "OS"? Also how many hard drives do you have in the box and how are they partitioned?
