Huawei B315-936 WiFi Issue
RVR
Durban
Hi,
For some reason my router has an issue with Wifi, the name of my wifi will show up then disconnect/disappear , then show up again and do this constantly. It's basically unusable.
Its up to date too, i did check.
Any possibile fix?
Easiest would be to change the channels. You probably have some neighbours whos wifi channels are impacting and conflicting with yours.
Any channel between 6 to 10 usually works for me.
Going to try this later. Thanks, will update.
