Huawei B315 router battery
Mariuspay
Pretoria
Item wanted : Huawei B315 router battery
Is packaging essential?: Nope
Desired age and condition: Good condition
Willing to accept a shipped item: Yes
Buy 12v battery and cable and charger sorted. This is what we do for our B618 router lasts 2 days, obviously dependant on AH tho
Apologies for noobz question. But any specific recommendations ito equipment eg charger.
Issue I assume would be to get power from 12V battery to charger to be able to charge the router?
Any electronics store can help with the appropriate charger.
But in short you do the following:
1. Power cuts.
2. Remove power cable from router.
3. Plug battery cable into router till power returns.
4. Power returns.
5. Unplug battery and plug in power cable.
6. Charge battery.
Rinse repeat - hope that helps
1. Power cuts.
4. Power returns.
6. Charge battery.
Thanks the process easy.
Its the issue of from battery to charger to router. But will check at electronics store for solutions. Had a sherlock for alarms and cctv. Fitting battery easy but connection from sherlock to router was the missing part. Returned to Takealot.
oh you have to manually connect and disconnect its not the same as your garage or alarm ssystem here.
The product you had was correct, all that was missing was buying a dc jack that fits your router. Connect to your 12v output from sherlo box and you’re sorted.
