Huawei B618s-65d 2600Mhz
sssutututu
So I did some searching and saw that the Huawei B618s-65d does support 2600Mhz, but it only shows 1800Mhz and 2300Mhz as an option as I can force it to. How do I switch it to 2600Mhz to run on Rain?
As far as I know the 65d only does 2600mhz FDD which is band 7, and the rain network uses band 38 which is TDD.
You would need to use the B618s-22d to make use of band 38 (2600mhz TDD) on the rain network.
I think so, before opening the box, you could check the sticker, it will tell you whether or not its a 65d or 22d, if they sent you the wrong one you can just return it to takealot without opening it and they will refund you.
I got the 65d as they said and I already bought the one that says 22D right now, so if they send the wrong one I will return and ask them for the right one. I know someone that would want to use the 65D and they don't care about the fastest speeds.
