huawei myfi router login not secure issue
Charles_cat
Not sure if I have the correct forum, please move it is not correct
Please can someone help PLEASE, i was always able to type in the IP address then log into the router to change settings, name etc.
now, it says connection not secure...
PLEASE how can i log in again/make a secure connection, fix this issue??
thanks
thanks
My browser does the same on http:// connections. All non https sites comes up with it in chrome and Firefox.
Doesn't bother me none. I know when to say continue anyway and when not to.
Just press continue.
Your router connection can never be fully secure unless you specially go through the motions of adding a certificate to it…which it more than likely doesn’t even support.
This is perfectly normal behaviour.
