Huawei P20 Pro screen protector
PDF_27
Centurion
Where could I get a screen protector that doesn't show the 'halo' around the edges due to the screen being curved? Anyone had success with finding one? I quite prefer the old fashioned plastic screen protectors because of that halo not being present. The tempered glass protectors break and crack way too easily.
I went to Huawei walk in centre in Melrose and they didnt have stock of the P20 pro original factory screen protector (plastic) so seeking any better alternative.
Some Vodacom and MTN shops have a Clearplex machine. They then "print" a soft plastic protector and stick it down with an alcohol based solvent. Curves around the edges nicely. It is the only one i have found that is case friendly for the Mate 20 Pro
