Huawei P9 battery
Dolby
I've always struggled with this battery and recently started putting it on Power Saver from the minute I take it off the charger (100%). Even then it only reflects an estimated time of 15hrs ...
Any of you guys, can you try the same, please? I've just reformatted and busy charging, but curious about others.
Also, the power saver is probably adds TWICE the length of time, so definitely working out. Aside from the notifications and auto sync, what else is it doing to save battery?
Nah.
If you go settings > battery > power saving mode ... It'll tell you how long it should last. With the mode on, it was giving me 14hrs!
After I reset, it's now 33hrs
Maybe your settings appear differently as I am still on EMUI4.
With 89% remaining, Smart power plan, ROG on. It estimates 32h left.
Ok sounds about right now that I've reset ... 100% > 33hrs on mine and 89% > 32hrs on yours. Was less than half before that. Unsure why.
