Huawei S7 slim review
MyWorld
Wes Transvaal
Anyone here with a decent review on this tablet?
I struggle to find anything of worth regarding this device, even XDA has very little on this device.
also thinkin of getting the deal thru mtn, mainly for ebooks, currently reading on my phone or pc, so not so great atm. howsabout a mini-review tomorrow @daniedj??
What puts me off is that it is still Android 2.x and not 3.x, so it is not REALLY a dedicated tab, more like a glorified phone.
If I cannot edit or check the odd document on it then it is of no use, I'm thinking of replacing my netbook with one of these, but I have my doubts.
i agree wrt android 2.x vs 3.x, but there are plenty of office editing apps available on the market. like I said my main function would be reading ebooks, but if I wanted more out of it I would root
No, the whole design of Android 3.x for tablets is to move away from the buttons you find on the bottom of the device (home, back, search, etc.) It is now handled directly from within the OS user interface with the touch screen.
That and if it is possible, I have yet to see it done.
The best we can expect at this point is 2.3.x
http://forum.xda-developers.com/forumdisplay.php?f=896 <-- Look for the CM7 rom.
Went to CellC to play with it for a while, then walked across to MTN to do a add sim.
Lets see how this pans out, it is much, MUCH faster and more responsive than my Motorola XT720, no lag at all. They said it will most probably arrive Friday at the latest Wednesday next week, then I'll post a decent review on here.
I've been playing around last night with it. It is very quick. I'm still to find a proper way to hold it. It is a bigger device than I'm used to. The 7inch screensize is perfect. I think I would've found the 9inchers too big. This is just right. I can recommend this device. It is the 3rd Android device I'm owning and it does work better than the others. (entry models though, SE X10 Mini and Vodaphone v845)
I've not had issues installing any of the usual apps. Installed MX Video Player and been passing some AVI's and MKV's to it. Works beautifully. The screen is fine. I find it responsive. It is not very viewable when looking at it from the top or bottom angle and in sun light... forget it. I was reading using Kindle in bed and watching movies, for that it is perfect.
Updating and installing I used about 500Mb last night.
The only funnies I found was that some apps using the motion sensor flips the axis so Google Sky Map is not working as it should. Did find a patch for that which I'll try to install today.The other seems to be that switching the device off and on while on charge does not work. When power cycling I had to take out the battery and switch on without charging.
The charger uses a wierd cable. It can be used for data transfer but it will be very short. Luckily I've a old Nokia USB cable for that. Also take note that it is not advised to charge the device off a PC but rather using the USB cable plugged into the supplied charger. Unless I'm mistaking the pictures on the cable.
Where did you find the patch, because I'm also looking for one. When I installed the Asus transformer water live wall paper the orientation was completely wrong.
Sent from my IDEOS S7 Slim using Tapatalk
I'm going to pick mine up within the hour, will post my findings also.
Will be interesting to see if it can be used what I need to be done.
Got mine, have not had time to really play with it yet.
I just have an error on inserting a micro SD card, it keeps giving me a dialogue informing that the card should be formatted. Will have a look at it later as soon as I have a bit of time to myself.
Lets review this then shall we?
The build quality is good, it is sturdy and solid, has a great feel to it, but it might be a tad bit on the heavier side. It is not uncomfortable but it is not super light either.
You get the tablet with charger, headphones, USB cable, (for charging from the wall plug, USB charging, and data transfer), battery and manual.
The USB cable is one of the weirdest I have ever seen, best read up on what is used for what. The only downside to USB charging is that you either need to turn of the phone or kill the backlight while charging rendering it useless when charging from a PC.
On first boot you see the MTN splash screen and you think to yourself, "Hmmmm, that's got to go!"
The device is pretty fast, I have no idea what speeds other get on the Samsungs but is no slouch either. It comes with 4GB internal SD storage and 512Mb ram.
The users interface you can look over yourself or go play with it at a CellC, pretty nice looking, especially the home screen.
Not much is included by default, it is pretty much a stock Android with almost no extra apps, you need to install what you need.
Handling is a bit awkward at first, you need to decide how you are going to place your hands on the device. I found that the palm of my right hand constantly touched the UI buttons on the right of the screen when holding it in both hands. This is a bit frustrating and you have to reprogram yourself to be extra tentative of this when holding it.
Now to the meaty part!
I got this to make my life a little easier and to downgrade on the netbook, for this it has to perform various tasks that I need done:
1) Accomplish networking tasks, like file sharing, ssh and the occasional ftp
2) Must be able to stream media
3) Must do simple office tasks (read, write and print documents)
4) Something that comes to mind along the way
Networking:
Lets start here since this is very important to me.
After playing with it for at least 15min I downloaded the necessary tools to get going.
Connectbot for ssh
Hacker's keyboard for a fully functioning keyboard (tab, up down left and right, etc.)
File expert to browse network shares
SSH was handled beautifully, and the extra keys made it a pleasure to use, tab completion and scrolling through history, it was so beautiful it brought tears to my eyes! Something that was a complete frustration on the Android phone is now a huge pleasure and already I have a warm and fuzzy feeling inside.
Browsing network shares is a breeze with File Expert, it is as simple as setting up the share and clicking the icon. I had no problems here. Now to the streaming. There are only a handful of apps that can handle streaming media on Android.
I installed RockPlayer Lite, used File Expert to browse to the file I wanted to play, choose "Open With". Once it starts downloading it will present you with another dialogue, just choose "Open" and RockPlayer should take over.
So, media streaming, check!
Now for a real world test, office applications!
I'm using Open Office Viewer since I use the open document format exclusively and King Office for creating documents.
It is not easy, a tablet was not meant as a word processing platform but if you are in a bind it will do. The other alternative is to get either a USB/BlueTooth keyboard if you are serious about this. I'll have to investigate the keyboard option at some stage.
If anyone knows of a better Office Suite that can handle the Open Document Format then I'll appreciate it if you could mention it.
Games.
I did not get this for the games, so if someone else could add to this then so be it.
All that is left is to test battery drain, hand on for this a bit longer.
Overall I'm happy, especially since it is such a breeze to do network tasks. Happy I got it.
Games.
All the games I have tried work well, including; Air Control, Angry Birds, Asphalt 5, Drag Racing, Diversion, Fruit Slice, Fire Ball, Fishing Kings, Replica Island, Battle for Wesnoth & MAME4droid.
I have found battery life to be acceptable, but not great. Depends a lot on what is is used for: WiFi & 3G drain battery very quickly :-(
I got about 9 hours of battery use from mine yesterday. Watching youtube, playing the odd game and watching a little bit of movies.
The benchmark score for this devices is 2505 using this app: AnTuTu benchmark.
Battery life
Thank for all the info here. This be my first Android! Loving what it can do for me. Battery life is good enough. Speed is fine. Screen is ok. I'm glad I did not spend double this to get a device that would've been similair.
