Hulu streaming help
viceroy
I have Hulu / Netflix all setup and going, so no trouble there.
Netflix streams fine with no interuptions.
However, even with Hulu set to the lowest SD setting (650kb/s) I get interuptions, pauses, etc which is highly annoying (even more so than the adverts)
4mb uncapped Axxess line.
using UnoTelly
Samsung smart TV to stream content, but even on my PC Hulu seems to struggle
Any suggestions on what to try to improve the situation?
using UnoTelly
Yep. Wait for EASSy - the undersea cable that normally carries Axxess' international traffic - to be repaired before passing judgement. I can stream 1mb/s SD fine on a 10mb line, but it goes for a loop as soon as I go for the 2mb stream. Before the cables were cut I could manage hulu's 2mb stream perfectly well on a 4mb line. I just hope things will return to those levels soonish.
Aah, thanks.
At least it doesn't appear to be my setup then.
Update.
My Hulu seems healthy now and was able to stream at 2mb with almost no pausing.
Hulu Plus on my Roku not working, just shows "loading..." on screen. Other channels like Netflix are fine. Please help
I've got the same issue :(
Does it also stop a few seconds after and tell you to check your internet connection?
Hey Smokey...
I'm using Playmo.tv's DNS servers configured on my PS3.
Thanks for the suggestion.... Well worth logging a ticket with their support desk to advise further.
