Hello everybody, these adapters work really well, no comebacks yet and we've sold loads of them. At R350 they really are much, much cheaper than original replacements.
Here are the tech specs:
Features
• High Efficiency
• Low Ripple/Noise
• Adopting PWM switch technology
• Six changeable connectors
• OCP, OVP, OPP, OTP, SCP
• SMD used numerously, compact construction, small volume
• Wholly hermetic plastic shell
• Reliability: MTBF >100, 000hours
General Specifications
• EMI: FCC Class B, EN55022 Class B
• Leakage Current: 3.5mA@264Vac/50Hz
• Dimension: W46×H30×L108 (mm)
Input Specifications
• Input Voltage Range 100 - 240Vac
• Input Frequency Range 47 - 63Hz
• Input Current 1.5A@90Vac/60Hz
• Inrush Current 50A@220Vac/50Hz
Safety
• CCC, UL, CE, TUV, CB, T-mark, CSA, NEMKO, CUL, GS, K-Mark, C-Tick, SAA, BSMI, VDE
Other Specifications
* Input voltage: 90-264Vac
* Input Frequency: 47-63Hz
* Output Voltage: 19Vdc
* Output Current: 0-4.74A
* Standby Power: 0.75W (No Load)
Please check that your current adapter is 18,5 to 19V and not more than 90W.
Features
• High Efficiency
• Low Ripple/Noise
Safety
