Hybrid "FTTC" Switch Over
Dean
@rpm
Perhaps I'm not the only one interested in getting official feedback from Openserve/ISP's on my query regarding the hybrid/FTTC model brought up in today's "Openserve’s big ADSL shutdown explained" article, so I thought I'd post and tag you for some investigative clout.
Pasted my original comment at the bottom of this post.
I have been asked the same by elderly person who lives in one of the specified September 1st DSL "cut-off" areas from the previous article, who is self-quarantining due to their covid risk profile - 4 months so far, and until their medical advisors say otherwise.
They aren't leaving their home at all, nor having guests, they fetch essential contactless deliveries from outside the house to be sanitised before use, etc... and certainly wouldn't consider inviting in installers for fibre.
So in order to maintain their only connection to the outside world, they would like to keep their DSL setup as-is inside their home.
That said, they wouldn't mind if they're switched to a "hybrid" solution whereby their ISP package changes, and/or exterior cabling is switched to fibre rather than copper - as long as no one has to come into their house to do so.
Of course once their self-quarantine ends, they'll be happy to make the switch to full fibre.
While I've given a very specific example above, it's also a general query about how the FTTC change-over will work for other cases where for whatever reason, someone in these 1st Sept "cut-off" areas can't get fibre physically installed within the next 5-ish weeks.
Another example could be holiday homes in other provinces, etc etc.
Could we get clarity from the powers that be, regarding what will actually happen in these cases, come 1 Sept?
And what the options are for people in this position without having installers come into their house?
My comment on the article was:
"Do existing DSL customers in those specified 'cut-off' areas need to rush to get fibre physically installed into their homes by 1 September?
Or would they be able to seamlessly migrate to this FTTC "Hybrid" product and keep using their already connected DSL router fed by the RJ11/copper, just with a different ISP product enabling the connectivity?"
  • Like
Reactions: Yuu
I had a chat with a Telkom techie today about the same thing.He said you would need a Fibre router for the FTTC connection.
  • Like
Reactions: Yuu
Ahh that's not sounding positive. Thanks for the feedback.
That said, I've been given some very incorrect advice from Telkom techies in the past, so perhaps it should still be queried with the higher-ups?
  • Like
Reactions: Yuu
Go LTE
Check Webafrica. Free router (big expense in general). Choice of Telkom or MTN based on location.
I have the 80GB + 80GB nightowl with Telkom.
I'm getting great speed in general.
About 34 to 44 Mbps average as the day goes.
Less than R600 per month.
  • Like
Reactions: Yuu
Go LTE
Check Webafrica. Free router (big expense in general. Choice of Telkom or MTN based on location.
I have the 80GB + 80GB nightmare with Telkom.
Yea that's plan B. Thanks for the advice and the feedback about the service.
Hoping to get a better idea of all the possible options before reverting to that.
Order > delivery.
Can't get much easier than that.
I don't see two elderly people use more than 30GB per month.
Check WA pricing. It only increases with higher data allocation.
Get a lesser package.
They literally need no contact with anyone with this solution.
LTE ia superior than ADSL IMHO.
The way he explained it to me was that you would use the same copper to the house and Telkom would swap the the router for a fibre router..might be wrong but that's what I understood it to be
There are converters for CAT cables to fiber, but I haven't heard of copper to fiber.
Why don't you let these nice old people go somewhere else for a few hours, get the fiber installers to install the fiber to the home, disinfect the house with foggers, and then let the old people come back?
Webafrica, Telkom LTE.
I live in the sticks. So I'm beyond impressed.
  • Love
Reactions: Yuu
Moved the Router :p
aaaaah smart move Hellkom, Welcome to FTTC (Fibre To The Curb) i really hope this is the road telkom is taking and they not perhaps rolling our Fibre To the Node,
So FTTC means Fibre cables are connected to a device in a pit then the last piece of copper from your wall socket to the pit will be used to connect you to the internet , inside your property you'll have a Fibre connection box which will connect to your existing rj11 sockets and a router which gets connected from the Fibre connection box then to the wan port on the router and this is really great move from Telkom BUT! ... God help us if Telkom is rolling our Fibre To the node then we effed as this is the most hated Mixed technology on the market as the existing nodes will have fibre running to the exchange and your copper from your home running all the way to the node which can either be close to your home or far from your home. FTTN is **** because if you far from the node just like ADSL speeds could be slower and if you close speeds could be faster, not forgetting if your copper lines is older than Abraham Lincoln you could experience alot of issues too
