Summary:
I recently bought a Hyundai Accent 1998
Odometer reads at 168 000 km
From the owner I learned that it was mostly only driven short distances
I believe this coupled with the fact that it had missed a lot of Oil changes, may have resulted in carbonisation inside the engine compartment.
I have a couple of problems and I was hoping there are members here who can help me with some guidance on the best sollution for these problems.
1. Vehicle producing a lot of smoke
The car creates huge amounts of smoke when starting & driving the vehicle. I do not know how bad the smoke is while driving, but after returning home at night everyone chokes on the exhaust fumes.
2. Consumes a lot of Oil
I filled up with oil when I left from Pretoria and when I arrived at Bloemfontein the engine was half full (positive eh?) There is no leakage of oil from below the vehicle.
3. Low on power
Vehicle does not have a lot of power, struggles a lot to get up and over a hill..
This situation is slightly better after we replaced the clogged up sparkplug (read below)
4. Vehicle shakes when driving
Whenever I go from 3rd to 4th gear the vehicle starts to shake excessively, after replacing a clogged up sparkplug this problem was mostly resolved.
The mechanic gave me 2 sollutions regarding the smoke:
(A) Clean engine using engline flush
The mechanic had me excited when he said the smoke can be from various things, he mentioned the gunk that has collected on the inside of the engine because of its skipped oil changes.
He mentioned that by removing the said gunk I could also help resolve the excessive smoking problem. However, the plan he had was to use Engine Flush (Oil Flush) to clean out the dirt from the engine.
I am always sceptical of any advice, so I did some research on the internet myself.
What I found out was that engine flush is a risky thing to put in your engine.
People's opinions vary greatly on the safety and efficiency of using engine flush to remove carbonisation.
Some claim that engine flush will loosen carbonised debri from the engine but deposit it in other places of the engine where it wouldn't be removed even after doing the mandatory oil change afterwards.
This left over mixture of carbonised debris may lead to clogged up pipes and resulting in engine damage.
(B) Open engine and do ring service (and clean engine carbonisation)
I am leaning towards this option. I doubt if my timing belt has ever been replaced, so perhaps it is a good idea to let the ring service be done and get it over with.
What are your opinions on cleaning a messy engine such as mine, should I let the mechanic do a ring service + clean the engine, or should I first try the engine flush even though so many people vote against it?
3. Low on power
