Hyundai Atos flicker (indicator) light
betty85
Candy Mountain
Hi all
Can anyone tell me the exact procedure to replace the front flicker globe in a Hyundai Atos 2nd generation (2007 model)?
It's not in the same fitting as the headlights and park globes. Also it's doing that high speed on off effect, but only on the right hand side and not when using hazards - I understand this might have to do with a faulty relay, but I'm not sure which one is which?
I just changed my Corolla left indicator lightbulb yesterday. The indicator light was flicking fast on the dashboard, but outside, the lightbulb was burnt out/off.
The previous time I had this issue both indicator lights were flicking fast, both on the dashboard and outside - that was because my battery was being overcharged - I had to change the alternator
It probably is the bulb that failed, check that side to see if it still works. If not then replacing it should fix the fast flicker.
Haha, your battery can't really overcharge in the sense that you mean, it is the voltage regulator on the alternator that was the problem (hence the alternator replacement) ;)
Betty85, did you ever got this sorted?
My wife's car have the same problem...
