MarmiteMonster
- May 15, 2023
I need a new battery charger but can't find one that fits my budget and specifications.
And I don't want one of those stupid smart chargers because they won't work for my intended purpose(I don't only charge batteries I use it to power stuff as well)
Budget
R1.5k might go higher if I can see the value in it.
Specs
Needs to do 12v and 6v 10amps (the higher the better)
Needs to have a knob to select amperage.
Ps the fuse is their for a reason don't put a bigger one in because the previous one blew for a reason. If the fuse can't blow the hole battery charger is going to.
I can repair mine I just need a full bridge rectifier and can't find one that is cheaper than a new battery charger.
Budget
Specs
