MarmiteMonster
- May 15, 2023
I need recommendations for a decent quality brushcutter that doesn't cost a arm and a leg.
PetrolPetrol, electric, battery, or hand-operated?
How big area do you want to do?
Wrong I don't always want to start while it's LS.These will always start, LS or not. No need for petrol.
Also half the time the "GRASS" I need to cut is waist heightPetrol, electric, battery, or hand-operated?
I used to buy those Electric jobbies.
They'd last a year or so.
Saw 6 hanging on the wall in a client's garaged.
Asked why.
He said they last 6 months, can't be fixed. He is determined to find a fix.
When my 2nd electric one packed up, I spent 3x more and bought a Ryobi 39cc petrol.
Lasted about 6 or 7 years.
Replaced it with another Ryobi, it's been going for 5 years so far.
Buy Petrol.
Stihl if you can, otherwise Ryobi is fine....
I was going to buy this Brushcutter until i read the reviews and the decided otherwise.Does anyone have experience with this Brushcutter.Yeah, I actually came here just to say get a Stihl and be done. Buy once cry once.
Do you perhaps know if their is spare parts available for them.I actually bought an adendorff 68cc brush cutter.
Noisy as they come but perfect for my application.
Would not recommend as a yard machine due to noise level but if you are doing some serious bundu bashing it is the way to go.
I could cut telephone poles down with this thing if I wanted to.
Adendorff's tools are in a different league to the usual Builders' hobbyist rubbish, they are industrial-strength, have no fiddly bits, and most of the time they are cheaper. The Honda motors are great as long as they are assembled in Japan.I actually bought an adendorff 68cc brush cutter.
