I need some help on these instructions please
kronoSX
Capetown home to gang stars
Enable Nethunter HID gadget function​
How to use it​
  1. Press your volume key once to test the input device
  2. Choose which usb gadget driver type for your kernel, Vol+ is thedefault one, and Vol- is the older one, which also called Android Composite Gadget that compiled with the kernel option CONFIG_USB_G_ANDROID=y.
  3. After successful installation of this magisk module, reboot and execute setprop sys.usb.config win,hid,adb, and there should be/dev/hidgX devices, then connect usb to PC and apps that support gadget will work, such as USB Keyboard.
NOTE: This magisk module will edit/restore your /vendor directorywhen executing install/uninstall functions, and enable/disable modulewill do nothing.
The words in bold i do not understand what to do there,Do i open a adb shell as root and type those in or must i find the nethunter app and do this.
How to use it​
Adb shell over USB to your computer or any Android terminal app such as Jack Palevich's Terminal emulator
you mean i must do this from the phone terminal to pc.I been doing it the other way round.
I open adb on pc and tried this.
So explain exactly what i must do please,I got termux installed as root
