I need your help.
Rickster
EVGA Fanatic
Joe'berg
Hi all,
I would just like to get some info on a EVGA GTX 660/Ti/FTW/Signature edition, if anyone has any of these cards could you please do me a favour and measure the thickness of the card and post it here in Millimetres ,it should be the thinnest part of the card.
Ill post Part numbers and pictures, thank you.
EVGA 02G-P4-3664-KR GeForce GTX 660 Ti FTW
EVGA 02G-P4-2662-KR GeForce GTX 660 Superclocked
How much accuracy do you need? You could probably calculate it down to the millimeter just off those pics...esp if you correct for perspective.
If I may ask, why do you need the precise dimensions? Is half a centimeter really that much of a problem?
Well my current setup is 2xPCIe one is for my GTX 460 and the other is for my Sound card, I need to make sure that the card will not A)Have reduced airflow with the new card and B) not "bend" the sound card.
A picture will be provided of my setup.
Hi res Picture
Not sure if you've checked the site but according to EVGA both of them are 111.15mm.
I can't find anything that can confirm the dimensions of the exact card, but similar cards(albeit from different manufacturers) range between 38mm - 42mm.
References:
http://www.xbitlabs.com/images/graphics/geforce-gtx-660-ti/table-spec.png
http://www.intunedonline.net/wp-con...derlands-2-GTX-660-Ti-graphics-card-specs.jpg
Here's also an image of the card in another board, but I doubt it's of any use due to the parallax error:
http://i105.photobucket.com/albums/m216/87wagon/NewCase1.jpg
Perhaps you could mail them for a definitive answer? Alternatively, try giving Evetech a call to ask them if they could physically measure the card. I'm sure they won't mind.
References:
That last picture looks similar to my current GFX card placement, so I think this card will match my current card.
On topic, does anyone know where to buy the EVGA 02G-P4-2662-KR GeForce GTX 660 Superclocked new?
It seems as if the whole EVGA GTX 600 series is discontinued :cry: and the 700 series is kuk expensive.
PS im not interested in the Asus or MSI 600 series, only EVGA
