I washed a pillow won't drain
hi everyone I washed my pillow and the stuffing came out and now my washing machine won't drain.
how do I fix it?
As a non-plumber, I would at least check if outlet pipe is clear. Chances are that you will get better suggestions than this but hey I tried.
if it is a front loader at least, there should be a small little access panel near the bottom right generally, open it and remove the cap, there is probably something stuck in there, but be prepared for the flood. You should probably start by first checking the outlet pipe.
how do I fix it?
What type of washing machine?
Either the filter, pump or the drain is blocked.
This, had something very similar a couple years back (not a pillow but drainage still blocked).
Im more interested in what steps you have taken so far to try and drain it
