i5 and compatible mobo with wifi*
wizdumb
now randburg
i am currently looking at upgrading my pc and my 1st step is cpu and mobo
looking for
1) i5 preferably a 3570K
2) motherboard that is compatible with the cpu, and if at all possible has built-in wifi, maybe a ASUS P8Z77-V (or anything similar
*3) depending on what the above comes, also 8gb of ddr3 ram (cheapest option)
looking for
If you plan to overclock: 3570K
If you don't plan to overclock: 3470
If you want or have an ITX case: GIGABYTE GA-H77N-WIFI or ASRock Z77E-ITX. I'll pick ASRock in this case.
ASUS P8Z77-V is a good option if you don't want an ITX mobo.
Rebeltech had a Gigabyte Z77-UD3H motherboard with WiFi a while ago. Try and find another supplier with this board.
3) RAM: Value - ADATA AXDU1333GW8G9-1G, 8GB, DDR3 1333MHz
Rather go for: G.Skill F3-1600C9D-8GAB, Ares
thanks emile, will check the specs out on the parts you posted...
...don't know what itx is, but will see what google says
[edit] first find if all the parts are compatible
then i can go shopping :)
All the parts will be compatible. Don't know what other components you have, but these are all compatible. ITX is basically very small and compact motherboards, excellent for HTPC.
