i7 motherboard help
serium
Need help dont know which would be best for a gaming rig
Asus Rampage II Gene
or
Asus P6T Deluxe V2
i have the v2. great board.
i am guessing that neither board is likely to hold you back.
Rampage II Gene, definitely. The P6T Deluxe is a budget i7 board as far as I understand.
There are three boards:
P6T
P6T Deluxe
P6T Deluxe v2
I am guessing you are talking about the 1st
Both same performance, Rampage aimed more at gamers but certainly isn't going to give you better performance.
The deluxe comes with a beter bundle it has more expansion slots and beter I/O (2 gigbit lan) beter overclocking features
100% Correct.
I had the same choice to make...
Cool thing with the Rampage is the dual Bios thing. Other than that, performance etc is pretty much identical. There is a review on the V2 and the rampage somewhere. Even ocing ( Below like 3.6ghz ) The V2 was actually better.
Ive got the Asus P6t and I must say. Very nice...
Had a DFI X58 board B4 this and it was faulty :(
