I tried secureix free VPN ( http://www.secureix.com ) today and it seems if it is working but still slow speeds but it is downloading and i am capped and I am thinking of getting me a 3 day subscription.
and it is easy to setup and with 1Gig email address with 50MB attachment limit.
PPTP Server: vpn.secureix.com
To setup a VPN connection under Microsoft Windows follow these steps:
1. Enter the 'Control Panel'
2. Select 'Network Connections'
3. Click on the "Create a new connection link"
4. Select "Connect to the network at my workplace"
5. Select "Virtual Private Network Connection"
6. Enter "SecureIX" as the company name
7. Select "Do not dial the initial connection"
8. Enter "vpn.secureix.com" as the Host name
9. Check the "Add a shortcut to this connection to my desktop"
10. Click "Finish"
The first time you connect you will be asked for the user name and password. Enter the same user name (including the @secureix.com) and password you used when creating your account into your VPN connection window. We suggest that you click the save password so you don't have to re-enter it each time you turn on the VPN.
You can also enable the "automatically re-dial this connection" feature if you wish for it to remain on at all times.
10. Click "Finish"
