IBurst transparent Proxy Is BROKEN!! (and how to fix it)
rikf
Basically they are not allowing the proxy to forward certain http commands that some programs use. Iv tried contacting wbs over both the phone and email and not once have I even spoken to a human or gotten an email reply. This is the copy of the email I have sent them I am posting it here so that hopefully some iburst techie will read it. I would also like to point out that the [email protected] mail box is full. It would be nice if someone was actually reading the email I have been sending over the past week or so.
----------------Being Email -----------------------------------------
Hello
Your Proxy is BADLY broken.
One example is subversion (a source version management system). I NEED this system for work. It is absolutely CRITICAL that you get this fixed out A.S.A.P
Please have a look at the instructions on this page http://subversion.tigris.org/faq.html#proxy
Is is really simple to fix this problem and simply involves adding ONE line to your squid config. (normally found in /etc/squid/squid.conf)
if you are running a version of squid after version 2.4 add this line
extension_methods REPORT MERGE MKACTIVITY CHECKOUT
otherwise if you are running a version of squid before version 2.4 use add this line
extension_methods REPORT MERGE MKACTIVITY CHECKOUT PROPFIND
to your squid.conf
Please treat this as a matter of utmost urgency and forward it on to a network administrator. Please would you keep me informed of the progress that is being made to solve this problem.
------------------------END EMAIL---------------------------------------------
Iburst's inaction in this matter is really starting to irritate me as I really need to be able to use that program for work. So if anyone from Iburst reads this. FIX IT!
